BT.com
Wishlist
Belkin Advance Secure 8-Port Keyboard/Mouse Switch; TAA
Belkin Advance Secure 8-Port...
£1,086.33
Hurry, only 3 left in stock!
£1,086.33
Add to wishlist
Delivery
Standard 1-3 working days
Seamless cursor and keyboard switching allows the user to change automatically from one highly isolated computer system to another as the mouse cursor crosses display borders, without having to push any buttons. Every system remains visible on its own display, continuously and simultaneously, while the Belkin Advanced Secure KM Switch keeps them isolated and secure.
The Belkin Advanced Secure KM Switch is ideal for data-intensive applications where information from multiple secure sources must be viewed and compared on multiple displays in real time. Analysts and operators in defense and intelligence, banking and trading, or complex command and control environments will benefit immediately and immensely from seamless switching with cursor movement.
Belkin Advanced Secure KM Switch - keyboard/mouse switch - 8 ports - desktop
Keyboard/mouse switch - 8 ports - PS/2, USB
Enclosure Type
Desktop
Subtype
KVM
AC 120/230 V ( 50/60 Hz )
44.5 cm x 20.2 cm x 4.3 cm
4.5 kg
United Kingdom
3 years warranty
Bundled Services
3 years warranty
Enclosure Type
Desktop
Subtype
KVM
Keyboard / Mouse Interface
PS/2, USB
Status Indicators
Port status, power
2 x USB - Type A , 2 x keyboard (PS/2) / mouse (PS/2) , 1 x audio - mini-jack , 8 x audio - mini-jack , 8 x keyboard (USB) / mouse (USB) - Type B
Internal power supply
TAA Compliant
United Kingdom
44.5 cm
20.2 cm
4.3 cm
4.5 kg
Limited warranty - 3 years
20 - 80%
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
Scroll to top
