BT.com
Wishlist
Belkin 6-Way Economy Surge Protector
Belkin 6-Way Economy Surge...
£9.03
More than 50 in stock
£9.03
Add to wishlist
Delivery
Standard 3-5 working days
Power surges and lightning strikes are not the only things that can damage your home electronic equipment. Simply switching appliances on and off can create electrical imbalances that cause cumulative, permanent damage to your computers, peripherals and electronic equipment. Decades of research and power protection development have led Belkin to the release of this Economic Surge Protection series. Using advanced design elements and top-quality construction as well as superior circuitry, the E-Series offers complete protection from power surges, AC contamination and spikes. As the leading developer of surge protection solutions, Belkin engineers and rigorously tests all its products to ensure your equipment will be safe from harmful electrical imbalances. The Belkin E-Series is your economical solution for clean, safe power and the industry's best in construction, ratings and safety standards. Over 38 million Belkin Surge Protectors units are protecting consumer electronics worldwide.
Belkin SurgeStrip E-Series - surge protector
Surge protector - external
English / United Kingdom
Input Voltage
AC 250 V
Input Connectors
1 x power BS 1363
Output connectors
6 x power BS 1363
White
Input Voltage
AC 250 V
Frequency Required
50 Hz
Input Connectors
1 x power BS 1363
6 x power BS 1363
Max Electric Current
13 A
Surge Suppression
Surge Response Time
1 ns
Surge Energy Rating
476 Joules
Max Spike Voltage
6000 V
Power cable - integrated - 1 m
Limited warranty - lifetime
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Compact and well built item
Reviewed by Bergamot Eng. on 23/09/2013
There is no extra plasticky bits that we sometimes have on cheap items.
The sockets tray is compact and it doesn't feel light at all.
I was wondering if one with a switch would be better but I thought a switch could be another rick of turning a computer down savagely.
4* Cable length...
Reviewed by Anonymous on 07/09/2006
This looks like a great value item (just bought one) but unfortunately I was caught out by the very short cable length and hence haven't tried it yet as it won't reach (just 1M cable only when I assumed it would be at least 2M or 3M as there is no mention of cable length in the description AFAICS?) so as long as you don't mind the very short cable length then I'd say this is a very good value purchase but if you need a longer cable (like me)then go with one of the more expensive surge protectors with a longer cable! :)
Scroll to top
