BT.com
Wishlist
Beats Pro Over-Ear Headphones - White
Delivery
Standard Due date unavailable
Beats Pro Over-Ear Headphones are made for heavy-duty use in the studio or in the club. Delivering superb audio, Beats Pro headphones give you deep bass response and sound across the spectrum. That's because they use no amplification or noise cancellation circuitry that adds other frequencies, colours the sound or compromises bass response.
The sound of the studio
By putting back the quality lost in modern-day file compression, Beats Pro headphones let you hear music the way it was originally heard by the artist in the studio.
Clear highs and deep lows
Steel and aluminium construction gives you a solid interior sound platform that provides the kind of bass that resonates deep in your chest when you play your music.
Tough, durable – built to last
No cheap plastic, no frayed cords. Beats Pro headphones are made with an aluminium gun metal frame with a black matte anodized finish, encasing overstuffed leather earcups.
True noise reduction
Heavily padded, pivoting ear cups give you a noise-cancelling effect without the need for power switches or batteries. It’s the real studio monitor experience in a headphone.
Easy to share
Plug your headphone cable into one earcup and the other automatically switches into output mode, letting your friends hear what you hear.
Highlights
  • Studio quality for ultra-accurate recording, mixing and playback.
  • Greater earcup foam density and precise fitting shut out external noise for awesome accuracy and clarity.
  • Plug your cable into one earcup and the other port switches to output mode, making it easy to share what you're listening to.
  • Backward rotating ear cups make it easy to monitor the room, studio or club with Beats Pro headphones at all times.
  • Yields superior sound isolation with maximum comfort and minimal ear fatigue.
  • Ear cups are removable and washable.
  • The heavy-duty, gold-plated 1/4-inch adapter ensures you're ready for any setup; attached tether prevents it from being left behind at your last gig.
Beats Pro - headphones with mic
Headphones - wired - 3.5 mm jack
Recommended Use
Portable electronics
White
Headphones Form Factor
Full size
Foldable
Wired
Sound Output Mode
Stereo
Microphone
On-cable
Microphone Operation Mode
Mono
Controls
Volume, answer/end, play/pause, next/previous track
12.9-inch iPad Pro; 9.7-inch iPad Pro; iPad (3rd generation); iPad 1; 2; iPad Air; iPad Air 2; iPad mini; iPad mini 2; 3; 4; iPad with Retina display (4th generation); iPhone 3G, 3GS, 4, 4S, 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, SE; iPod classic; iPod nano; iPod shuffle (1G, 2G, 3G, 4G); iPod touch
Headphones - 3.5 mm jack
19.7 cm
400 g
White
Body Material
Aluminium, steel
Recommended Use
Headphones
Circumaural
Foldable
Wired
Available Microphone
Sound Output Mode
Stereo
In-Cord Volume Control
Microphone
On-cable
Mono
Remote Control
Remote control
Supported Devices
Apple iPhone, Apple iPod touch, Apple iPad, Apple iPod
Controls
Connector Type
Headphones (mini-phone stereo 3.5 mm 4-pole)
Cable
Detachable Cable
Headphones cable , Headphones cable
Carrying pouch, 6.3 mm (1/4") stereo adapter
Apple 12.9-inch iPad Pro , Apple 9.7-inch iPad Pro , Apple iPad (3rd generation) , Apple iPad 1 , Apple iPad 2 , Apple iPad Air , Apple iPad Air 2 , Apple iPad mini , Apple iPad mini 2 , Apple iPad mini 3 , Apple iPad mini 4 , Apple iPad with Retina display (4th generation) , Apple iPhone 3G, 3GS, 4, 4S, 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, SE , Apple iPod classic , Apple iPod nano (1G, 2G, 3G, 4G, 5G, 6G, 7G) , Apple iPod shuffle (1G, 2G, 3G, 4G) , Apple iPod touch (1G, 2G, 3G, 4G, 5G, 6G)
Scroll to top
