BT.com
Wishlist
Beats Pill 2.0 Speaker - White
Colours:
Delivery
Standard Due date unavailable
The Beats Pill speaker is lightweight enough to take along and set up anywhere. It's also small enough to fit in whatever bag or luggage you're carrying out the door. So you'll always have high-quality sound wherever you are.
The new surround sound. Just tap two Pills together twice to make one Pill the left output and the other the right.
One charge gives you many hours of continuous play. Charge your Pill almost anywhere, from your Mac's USB port to any outlet.
Beats by Dr. Dre Pill 2.0 - speaker - for portable use - wireless
Speaker - for portable use
19 cm 4.5 cm
310 g
Speaker Type
Active
Audio Amplifier
Integrated
Bluetooth, NFC
Speaker Details
Speaker - stereo - 2 - active
White
Power Options
USB charging
Speaker battery rechargeable - Lithium Ion
12.9-inch iPad Pro; 9.7-inch iPad Pro; iPad; iPad 1; 2; iPad Air; iPad Air 2; iPad mini; iPad mini 2; 3; iPad with Retina display; iPhone 3G, 3GS, 4, 4S, 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, SE; iPod (4G, 5G); iPod classic; iPod mini; iPod nano (7G); iPod shuffle; iPod touch (3G, 4G, 5G)
Hands-Free Function
19 cm
4.5 cm
310 g
Enclosure Colour
White
Speaker System
Speaker Type
Active
Audio Amplifier
Integrated
Connectivity Interfaces
Bluetooth, Near Field Communication (NFC)
Transmission Range
10 m
Controls
Power on/off, volume, call answer, play/pause, next track, previous track
Additional Features
Daisy-chain capability
Speaker System Details
Speaker Details
Connector Type
Audio line-in (mini-phone stereo 3.5 mm) , Audio line-out (mini-phone stereo 3.5 mm) , DC power output (4 PIN USB Type A)
Carrying case, AC power adaptor, audio cable, USB cable
Power Source
Options
USB charging
Rechargeable - Lithium Ion
Run Time (Up To)
7 hour(s)
Apple 12.9-inch iPad Pro , Apple 9.7-inch iPad Pro , Apple iPad (3rd generation) , Apple iPad 1 , Apple iPad 2 , Apple iPad Air , Apple iPad Air 2 , Apple iPad mini , Apple iPad mini 2 , Apple iPad mini 3 , Apple iPad with Retina display (4th generation) , Apple iPhone 3G, 3GS, 4, 4S, 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, SE , Apple iPod (4G, 5G) , Apple iPod classic , Apple iPod mini , Apple iPod nano (7G) , Apple iPod shuffle (1G, 2G, 3G, 4G, 5G) , Apple iPod touch (3G, 4G, 5G)
Scroll to top
