BT.com
Wishlist
Be Quiet Silent Wings 3 PWM High Speed Case Fan 12cm Black Very Silent
Be Quiet Silent Wings 3 PWM High...
£18.33
27 in stock
£18.33
Add to wishlist
Delivery
Standard 3-5 working days
be quiet! SilentWings fans stand for advanced technology, virtually inaudible operation and superior cooling. The third generation of this amazing fan series offers unrivaled and uncompromising performance with a broad range of meticulous optimizations. They feature a smooth-running 6-pole motor, an advanced fluid-dynamic bearing, a unique airflow-optimized fan blade design and a fan frame with funnel-shaped air inlets. The SilentWings 3 120 mm model combines all of the above great features. It strikes the perfect balance between cooling and meets all the requirements to be a perfect choice for heat sinks, PC cases and radiators.
be quiet! Silent Wings 3 - case fan
Case fan
Package Content
Screws, Push Pins, silicone washers
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Fluid dynamic bearing
Rotation Speed
2200 rpm
Air Flow
73.33 cfm
Noise Level
28.6 dBA
Power Connector
4-pin fan connector
Pulse-width modulation (PWM) support
12 cm x 12 cm x 2.5 cm
137 g
Anti-vibration
3 years warranty
Case fan
Package Content
12 cm
12 cm
2.5 cm
137 g
Heatsink & Fan
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Rotation Speed
2200 rpm
Air Flow
73.33 cfm
Air Pressure
3.37 mm
Noise Level
28.6 dBA
Power Connector
4-pin fan connector
Operation Voltage
5 - 13.2 V
Start Voltage
4 V
Rated Current
0.37 A
Power Consumption
4.44 W
Cable Length
50 cm
MTBF
300,000 hour(s)
Anti-vibration
Limited warranty - 3 years
Be Quiet Silent Wings 3 PWM High Speed Case Fan 12cm...
£18.33
Save on this ideal PC Build kit!
Save £8.29
£37.50
Scroll to top
