BT.com
Wishlist
Be Quiet Silent Wings 3 14cm High Speed Case Fan Black Very Silent
Be Quiet Silent Wings 3 14cm High...
£18.61
3 in stock
£18.61
Add to wishlist
Delivery
Standard 3-5 working days
be quiet! SilentWings fans stand for advanced technology, virtually inaudible operation and superior cooling. The third generation of this amazing series offers unrivaled and uncompromising performance with a broad range of meticulous optimizations. They feature a smooth-running 6-pole motor, an advanced fluid-dynamic bearing, a unique airflow-optimized fan blade design and a fan frame with funnel-shaped air inlets. The SilentWings 3 140 mm high-speed model combines all of the above great features. The extremely high air pressure produced makes the fan especially suitable for use in powerful water cooling and air cooling set ups.
be quiet! Silent Wings 3 High Speed - case fan
Case fan
Package Content
Screws, Push Pins, silicone washers, adapter cable 12V to 7V, adapter cable 12V to 5V
Fan Diameter
140 mm
Fan Bearing
Hydrodynamic bearing
Rotation Speed
1600 rpm
Air Flow
77.57 cfm
Noise Level
28.1 dBA
Power Connector
3-pin plug
14 cm x 14 cm x 2.5 cm
167 g
Anti-vibration
3 years warranty
Case fan
Package Content
14 cm
14 cm
2.5 cm
167 g
Heatsink & Fan
Fan Diameter
140 mm
Fan Bearing
Rotation Speed
1600 rpm
Air Flow
77.57 cfm
Air Pressure
2.16 mm
Noise Level
28.1 dBA
Power Connector
3-pin plug
Operation Voltage
5 - 13.2 V
Start Voltage
4 V
Rated Current
0.14 A
Power Consumption
6 W
Cable Length
50 cm
Anti-vibration
Limited warranty - 3 years
Be Quiet Silent Wings 3 14cm High Speed Case Fan Black...
£18.61
Save on this ideal PC Build kit!
Save £10.63
£37.78
Scroll to top
