BT.com
Wishlist
Be Quiet Silent Wings 3 12cm Case Fan Black Very Silent
Be Quiet Silent Wings 3 12cm Case...
£19.89
£19.89
Add to wishlist
Delivery
Standard Due date unavailable
be quiet! SilentWings fans stand for advanced technology, virtually inaudible operation and superior cooling. The third generation of this amazing fan series offers unrivaled and uncompromising performance with a broad range of meticulous optimizations. They feature a smooth-running 6-pole motor, an advanced fluid-dynamic bearing, a unique airflow-optimized fan blade design and a fan frame with funnel-shaped air inlets. The SilentWings 3 120 mm model combines all of the above great features. It strikes the perfect balance between cooling and meets all the requirements to be a perfect choice for heat sinks, PC cases and radiators.
be quiet! Silent Wings 3 - case fan
Case fan
Package Content
Screws, Push Pins, silicone washers, adapter cable 12V to 7V, adapter cable 12V to 5V
Fan Diameter
120 mm
Fan Bearing
Hydrodynamic bearing
Rotation Speed
1450 rpm
Air Flow
50.5 cfm
Noise Level
16.4 dBA
Power Connector
3-pin plug
12 cm x 12 cm x 2.5 cm
137 g
Anti-vibration
3 years warranty
Case fan
Package Content
12 cm
12 cm
2.5 cm
137 g
Heatsink & Fan
Fan Diameter
120 mm
Fan Bearing
Rotation Speed
1450 rpm
Air Flow
50.5 cfm
Air Pressure
1.79 mm
Noise Level
16.4 dBA
Power Connector
3-pin plug
Operation Voltage
5 - 13.2 V
Start Voltage
4 V
Rated Current
0.12 A
Power Consumption
1.44 W
Cable Length
50 cm
Anti-vibration
Limited warranty - 3 years
Scroll to top
