BT.com
Wishlist
Be Quiet Silent Loop All in One 120mm CPU Liquid Cooler
Be Quiet Silent Loop All in One...
£102.52
£102.52
Add to wishlist
Delivery
Standard Due date unavailable
This product brings whisper-silent technology to the world of All-in-One watercooling, making liquid cooling an attractive option for those who want to overclock CPUs for maximum processing performance or cool high-power PC systems.
Thanks to its decoupled reverse-flow pump, Silent Loop works ultra-quiet and with practically no vibration. It comes in a premium all-in-one package designed for maximum compatibility and installation flexibility.
be quiet! Silent Loop 120mm - liquid cooling system
Liquid cooling system
Compatibility
LGA775 Socket, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket AM3+, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket, Socket FM2+, LGA2011-3 Socket, LGA1151 Socket
Heatsink Material
Copper
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Rifle bearing
Rotation Speed
2000 rpm
Air Flow
65.51 cfm
Noise Level
36.9 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Pulse-width modulation (PWM) support
1.287 kg
3 years warranty
1.287 kg
Heatsink & Fan
Compatible With
Heatsink Material
Copper
Heatsink Dimensions
153 mm x 128 mm x 45 mm
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Rifle bearing
Rotation Speed
2000 rpm
Air Flow
65.51 cfm
Air Pressure
2.23 mm
Noise Level
36.9 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Rated Current
0.3 A
Limited warranty - 3 years
Be Quiet Silent Loop All in One 120mm CPU Liquid...
£102.52
Save on this ideal PC Build kit!
Save £8.29
£121.69
Scroll to top
