BT.com
Wishlist
Be Quiet Shadow Wings 8cm Low Speed Case Fan
Be Quiet Shadow Wings 8cm Low Speed...
£9.56
4 in stock
£9.56
Add to wishlist
Delivery
Standard 3-5 working days
Low-noise operation due to high-quality rifle bearing. The parallel arrangement of recesses on the outer side of the bearing shaft ensure uniform circulation of the high-quality oil and make the fan very quiet. Mechanical noise is minimized by anti-vibration fasteners and the rubberized fan frame. The high-quality IC motor controller reduces electrical noise sources.
be quiet! Shadow Wings SW1 Low Speed - case fan
Case fan
Fan Diameter
80 mm
Fan Height
25 mm
Fan Bearing
Rifle bearing
Rotation Speed
1400 rpm
Air Flow
14.9 cfm
Noise Level
8.4 dBA
Power Connector
3-pin plug
8 cm x 8 cm x 2.5 cm
Anti-vibration
3 years warranty
Case fan
8 cm
8 cm
2.5 cm
Heatsink & Fan
Fan Diameter
80 mm
Fan Height
25 mm
Fan Bearing
Rifle bearing
Rotation Speed
1400 rpm
Air Flow
14.9 cfm
Air Pressure
0.97 mm
Noise Level
8.4 dBA
Power Connector
3-pin plug
Operation Voltage
5 - 12 V
Rated Current
0.12 A
Power Consumption
1.44 W
Anti-vibration
TUV S, RoHS, WEEE
Limited warranty - 3 years
Scroll to top
