BT.com
Wishlist
Be Quiet Shadow Wings 14cm Mid-Speed Case Fan
Be Quiet Shadow Wings 14cm...
£14.14
Hurry, only 1 left in stock!
£14.14
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Low-noise operation due to high-quality rifle bearing. The parallel arrangement of recesses on the outer side of the bearing shaft ensure uniform circulation of the high-quality oil and make the fan very quiet. Mechanical noise is minimized by anti-vibration fasteners and the rubberized fan frame. The high-quality IC motor controller reduces electrical noise sources.
be quiet! Shadow Wings SW1 Medium Speed - case fan
Case fan
Fan Diameter
140 mm
Fan Height
25 mm
Fan Bearing
Rifle bearing
Rotation Speed
1000 rpm
Air Flow
60.4 cfm
Noise Level
17.3 dBA
Power Connector
3-pin plug
14 cm x 14 cm x 2.5 cm
Anti-vibration
3 years warranty
Case fan
14 cm
14 cm
2.5 cm
Heatsink & Fan
Fan Diameter
140 mm
Fan Height
25 mm
Fan Bearing
Rifle bearing
Rotation Speed
1000 rpm
Air Flow
60.4 cfm
Air Pressure
0.81 mm
Noise Level
17.3 dBA
Power Connector
3-pin plug
Operation Voltage
5 - 12 V
Rated Current
0.2 A
Power Consumption
2.4 W
Anti-vibration
TUV S, RoHS, WEEE
Limited warranty - 3 years
£14.14
Save on this ideal PC Build kit!
Save £8.29
£33.31
Scroll to top
