BT.com
Wishlist
Be Quiet Shadow Rock Slim CPU Cooler
Be Quiet Shadow Rock Slim CPU...
£40.06
£40.06
Add to wishlist
Delivery
Standard Due date unavailable
With the introduction of Shadow Rock Slim, be quiet! brings silent and premium cooling technologies to the compact PC space. Shadow Rock Slim is not simply "another space saving cooler" - it is a first-class performer meant for gaming, multimedia and graphics-intensive compact PCs.
Featuring an unrivaled price-performance ratio, matchless be quiet! low noise operation, and the distinctive attention to quality and detail, Shadow Rock Slim truly is a best choice in the compact CPU cooler category.
be quiet! Shadow Rock Slim - processor cooler
Processor cooler
Package Content
Thermal paste
Compatibility
Socket 754, Socket 940, LGA775 Socket, Socket 939, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket AM3+, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket, Socket FM2+
Heatsink Material
Aluminium with copper base
Fan Diameter
135 mm
Fan Height
22 mm
Fan Bearing
Rifle bearing
Rotation Speed
1400 rpm
Air Flow
67.8 cfm
Noise Level
11.5/18.7/23.7 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
4 copper heatpipes (6 mm)
13.7 cm x 7.4 cm x 16.1 cm
729 g
3 years warranty
Processor cooler
Package Content
Thermal paste
13.7 cm
7.4 cm
16.1 cm
729 g
Heatsink & Fan
Compatible With
Heatsink Material
Heatsink Dimensions
161 mm x 130 mm x 52 mm
Fan Diameter
135 mm
Fan Height
22 mm
Fan Bearing
Rifle bearing
Rotation Speed
1400 rpm
Air Flow
67.8 cfm
Air Pressure
2.1 mm
Noise Level
11.5/18.7/23.7 dBA
Noise & Performance Details
11.5 dBA at 600 rpm , 18.7 dBA at 900 rpm , 23.7 dBA at 1400 rpm
Power Connector
4-pin fan connector
Rated Voltage
12 V
Rated Current
0.11 A
Limited warranty - 3 years
Scroll to top
