BT.com
Wishlist
Be Quiet Shadow Rock LP Heatsink & Fan All Intel
Be Quiet Shadow Rock LP Heatsink &...
£37.53
37 in stock
£37.53
Add to wishlist
Delivery
Standard 3-5 working days
Fitting everything you want into a HTPC or small form factor PC can be tough, but quietly cooling those cramped components is a far tougher proposition. The ultra-compact Shadow Rock LP premium CPU cooler efficiently and economically solves this special problem.
If you are seeking the best possible mix of premium cooling performance for restricted space situations, remarkably quiet operations, eye-catching design, and a highly attractive price in the compact CPU cooler segment, seek no further. Shadow Rock LP is the cooler for you.
be quiet! Shadow Rock LP - processor cooler
Processor cooler
Compatibility
LGA775 Socket, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket AM3+, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket, Socket FM2+
Heatsink Material
Aluminium with copper base
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Rifle bearing
Rotation Speed
1500 rpm
Air Flow
87 cfm
Noise Level
14.8/18.6/25.5 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Pulse-width modulation (PWM) support, 4 copper heatpipes (6 mm)
13.4 cm x 12.2 cm x 7.54 cm
390 g
3 years warranty
Processor cooler
13.4 cm
12.2 cm
7.54 cm
390 g
Heatsink & Fan
Compatible With
Heatsink Material
Heatsink Dimensions
134 mm x 122 mm x 50.4 mm
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Rifle bearing
Rotation Speed
1500 rpm
Air Flow
87 cfm
Air Pressure
1.25 mm
Noise Level
14.8/18.6/25.5 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Rated Current
0.09 A
Power Consumption
1.1 W
Cable Length
22 cm
Mounting Kit
Included
MTBF
80,000 hour(s)
Limited warranty - 3 years
Scroll to top
