BT.com
Wishlist
Be Quiet Dark Rock TF Heatsink & Fan All Intel
Delivery
Standard Due date unavailable
Compact PCs pose significant design challenges, not least of which is how to quietly cool a high-performance, overclocked CPU in a cramped space. be quiet!'s Dark Rock TF offers a solution to this challenge.
This top-flow cooler with two powerful heat sinks is an extension of the well-established successful be quiet! product series Dark Rock and a compact cooling beast. It is designed to bring the famous be quiet! silent technology into your PC. With great performance-to-noise ratio, it strikes the perfect balance between cooling and serenity with absolutely no compromise in silence and performance.
be quiet! Dark Rock TF - processor cooler
Processor cooler
Dark nickel
Compatibility
LGA775 Socket, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket AM3+, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket, Socket FM2+, LGA2011-3 Socket, LGA1151 Socket
Heatsink Material
Aluminium with copper base
Fans Qty
Dual
Fan Diameter
135 mm
Fan Height
22 mm
Fan Bearing
Fluid dynamic bearing
Rotation Speed
1400 rpm
Air Flow
67.8/113.8 cfm
Noise Level
11.9/19.3/26.7 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
6 nikel plated copper heatpipes (6 mm)
16.26 cm x 14 cm x 13.08 cm
810 g
Anti-vibration, nickel plated, Silent Wings
3 years warranty
Processor cooler
16.26 cm
14 cm
13.08 cm
810 g
Dark nickel
Heatsink & Fan
Compatible With
Heatsink Material
Fans Qty
2
Fan Diameter
135 mm
Fan Height
22 mm
Fan Bearing
Rotation Speed
1400 rpm
Air Flow
67.8/113.8 cfm
Air Pressure
1.85 mm
Noise Level
11.9/19.3/26.7 dBA
Noise & Performance Details
11.9 dBA at 700 rpm , 19.3 dBA at 1050 rpm , 26.7 dBA at 1400 rpm
Power Connector
4-pin fan connector
Rated Voltage
12 V
Rated Current
0.2 A
Cable Length
22 cm
Mounting Kit
Included
MTBF
300,000 hour(s)
RoHS
Limited warranty - 3 years
Scroll to top
