BT.com
Wishlist
Be Quiet Dark Base Pro 900 Gaming ATX Case - Black/Orange
Be Quiet Dark Base Pro 900 Gaming...
£201.69
Hurry, only 1 left in stock!
£201.69
Add to wishlist
Delivery
Standard 1-3 working days
Outstanding flexibility and silence
be quiet! Dark Base Pro 900 Orange is the perfect case for all of those who expect the highest standards when it comes to modularity, compatibility and design.
  • Relocatable motherboard tray with the possibility of an inverse layout
  • Repositionable HDD tray with single HDD slots for individual space requirements
  • Three virtually inaudible be quiet! SilentWings® 3 140mm PWM fans
  • Advanced PWM hub and manual fan controller supports up to four PWM and four 3-pin fans
  • Full-circuit airflow system with noise-reducing vents all around the case
  • Ready for radiators up to 420mm on top, front, back and base
  • Completely sound insulated with decoupled motherboard, PSU and drives
  • Fully windowed side panel from tinted and tempered glass
  • Eye-catching, freely positionable LED illumination
  • Wireless charger for Qi enabled devices (e.g. smart phones)
  • Three years manufacturer’s warranty
  • German product conception, design and quality control
be quiet! Dark Base Pro 900 - mid tower - extended ATX
System cabinet
Mid tower
Orange
I/O Connectors
2 x USB 3.0 , 2 x USB 2.0 , 1 x headphones , 1 x microphone
Supported Motherboards
ATX, microATX, Mini-ATX, Extended ATX, XL-ATX
System Cabinet Features
Screwless drive bays, side panel dust filter, removable dust filter, vibration damping, front dust filter, water cooling holes, cable management system, removable HDD cage, bottom dust filter, airflow channels, integrated Qi (wireless charging dock), RGB illumination
No power supply
24.3 cm x 57.7 cm x 58.5 cm
14.39 kg
3 years warranty
Mid tower
Max Mainboard Size
Extended ATX
Internal Bays Qty
8
Front Accessible Bays Qty
2
Product Material
Aluminium, steel, ABS plastic
Orange
Cooling System
Front: 140 x 140 x 25 mm fan x 2 / 1000 rpm / 59.5 cfm / 15.5 dBA / SilentWings 3 , Rear: 140 x 140 x 25 mm fan x 1 / 1000 rpm / 59.5 cfm / 15.5 dBA / SilentWings 3 , Front: 120/140 mm fan mount x 1 , Top: 120/140/180 mm fan mount x 4 / 4 x 120 mm or 3 x 140 mm or 1 x 180 mm fan supported , Bottom: 120/140 mm fan mount x 2
CPU Cooler Max Height
185 mm
Video Card Max Length
470 mm
Expansion Bays
2 (total) / 2 (free) x front accessible - 5.25" , 1 (total) / 1 (free) x internal - 2.5" , 7 (total) / 7 (free) x internal - 3.5"
Expansion Slots
8
2 x USB 3.0 , 2 x USB 2.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
PWM hub
RoHS 2011/65/EU
No power supply
24.3 cm
57.7 cm
58.5 cm
14.39 kg
Limited warranty - 3 years
Be Quiet Dark Base Pro 900 Gaming ATX Case -...
£201.69
Save on this ideal PC Build kit!
Save £8.40
£220.91
Scroll to top
