BT.com
Wishlist
Be Quiet BN272 Pure Power 10 400W 80+ Silver PSU
Be Quiet BN272 Pure Power 10 400W...
£48.13
18 in stock
£48.13
Add to wishlist
Delivery
Standard 3-5 working days
Exceptionally Quiet, Superior Reliability, Great Value
Whether you’re assembling a very quiet system, upgrading an existing PC, or building a multi-GPU gaming system, your build will benefit from this PSU series that simply has the best combination of features at a very popular prize.
  • Two 12V-rails and up to four PCI-express connectors for powerful multi-GPU systems
  • 80PLUS ® Silver / Bronze certification with up to 91% power conversion efficiency
  • Exceptionally quiet operation thanks to use of a silence-optimized 120mm be quiet! fan
  • Stable operation thanks to DC-to-DC power conversion technology (700W - 400W)
  • Attractively sleeved cables simplify component installation, increase airflow and improve cooling
  • Top component protection with full suite of safety features
  • Meets latest Intel ® C6/C7, ErP and Energy Star guidelines
  • 3-year manufacturer’s warranty
  • Product conception, design and quality control in Germany
be quiet! Pure Power 10 - power supply - 400 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.4
80 PLUS Certification
80 PLUS Silver
1.86 kg
English, German, French, Polish, Russian, Spanish
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
400 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin +12V with detachable 4 pin section , 2 x 8 pin PCI Express power with detachable 2 pin section , 2 x 4 PIN internal power , 5 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector , 2 x 4 PIN internal power
Cooling System
120 mm fan
Cable ties
15 cm x 15 cm x 8.6 cm
Environmental Standards
ENERGY STAR
3 years warranty
Scroll to top
