BT.com
Wishlist
Be Quiet BN271 Pure Power 10 350W 80+ Bronze PSU
Be Quiet BN271 Pure Power 10 350W...
£44.08
7 in stock
£44.08
Add to wishlist
Delivery
Standard 3-5 working days
Exceptionally Quiet, Superior Reliability, Great Value
Whether you’re assembling a very quiet system, upgrading an existing PC, or building a multi-GPU gaming system, your build will benefit from this PSU series that simply has the best combination of features at a very popular prize.
  • Two 12V-rails and up to four PCI-express connectors for powerful multi-GPU systems
  • 80PLUS ® Silver / Bronze certification with up to 91% power conversion efficiency
  • Exceptionally quiet operation thanks to use of a silence-optimized 120mm be quiet! fan
  • Stable operation thanks to DC-to-DC power conversion technology (700W - 400W)
  • Attractively sleeved cables simplify component installation, increase airflow and improve cooling
  • Top component protection with full suite of safety features
  • Meets latest Intel ® C6/C7, ErP and Energy Star guidelines
  • 3-year manufacturer’s warranty
  • Product conception, design and quality control in Germany
be quiet! Pure Power 10 - power supply - 350 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.4
80 PLUS Certification
80 PLUS Bronze
1.8 g
English, German, French, Polish, Russian, Spanish
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
350 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin +12V with detachable 4 pin section , 1 x 8 pin PCI Express power with detachable 2 pin section , 2 x 4 PIN internal power , 5 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector , 2 x 4 PIN internal power
Cooling System
120 mm fan
Cable ties
15 cm x 15 cm x 8.6 cm
Environmental Standards
ENERGY STAR
3 years warranty
ATX12V 2.4
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
350 Watt
Output Current
+3.3V - 21 A , +5V - 15 A , +12V1 - 18 A , +12V2 - 18 A , -12V - 0.3 A , +5VSB - 2.5 A
Efficiency
84% at 100% Load, 87% at 50% Load, 84% at 20% Load
Power Factor (PF)
0.99
80 PLUS Bronze
Cable ties
Cooling System
120 mm fan
Overheat protection, over current protection, over voltage protection, overpower protection, undervoltage protection, dual 12V rails, short-circuit protection, active CLAMP circuitry, DC-DC technology, Synchronous Rectifier (SR) technology
TUV, BSMI, DEMKO, FIMKO, NEMKO, SEMKO, CB, FCC, RoHS, WEEE, cTUVus, ERP, RCM, cRUus, CU
ENERGY STAR
Limited warranty - 3 years
15 cm
15 cm
8.6 cm
1.8 g
Shipping Width
26 cm
Shipping Depth
20.2 cm
Shipping Height
9.8 cm
Shipping Weight
2.3 kg
Scroll to top
