BT.com
Wishlist
Be Quiet BN236 Straight Power 10 CM Power Supply 700 Watts
Be Quiet BN236 Straight Power 10 CM...
£115.83
£115.83
Add to wishlist
Delivery
Standard Due date unavailable
Be quiet! Straight Power 10 700W CM provides a new level of silent performance for systems that demand whisper-quiet operation without facing the slightest compromise in power quality. Special German team has updated and designed even more premium features into this generation of the Straight Power series, which make the Straight Power 10 700W CM more silent than ever and a clear 'Best Choice' for new systems and as a replacement in existing systems.
be quiet! Straight Power 10 700W CM - power supply - 700 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.4/ EPS12V 2.92
80 PLUS Certification
80 PLUS Gold
2.57 kg
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
700 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin +12V with detachable 4 pin section , 4 x 8 pin PCI Express power with detachable 2 pin section , 4 x 4 PIN internal power , 11 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector
Cooling System
135mm fan
Cable ties, thumbscrews
15 cm x 16 cm x 8.6 cm
Environmental Standards
ENERGY STAR
5 years warranty
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
700 Watt
Output Current
+3.3V - 25 A , +5V - 25 A , +12V1 - 18 A , +12V2 - 18 A , +12V3 - 22 A , +12V4 - 22 A , -12V - 0.5 A , +5VSB - 3 A
Efficiency
93%
80 PLUS Gold
Power cable - external - 1.5 m
MTBF
100,000 hours
Cooling System
135mm fan
Over current protection, over voltage protection, overpower protection, SLI ready, undervoltage protection, cable management, short-circuit protection, Multi-GPU Technologies Supported, 4 x 12V rail, CrossFireX ready, thermal protection, fluid dynamic bearing cooling fan
TUV, BSMI, CB, FCC, RoHS, WEEE, cTUVus, ERP
ENERGY STAR
Limited warranty - 5 years
Sound Emission
10.5 dBA
15 cm
16 cm
8.6 cm
2.57 kg
Shipping Width
24.8 cm
Shipping Depth
32.8 cm
Shipping Height
10.2 cm
Shipping Weight
3.15 kg
Scroll to top
