BT.com
Wishlist
Be Quiet BN211 Power Zone Power Supply 750 Watts
Be Quiet BN211 Power Zone Power...
£110.38
£110.38
Add to wishlist
Delivery
Standard 1-3 working days
The be quiet! Power Zone is home for discerning gamers and PC enthusiasts seeking high power, top performance and great features. Power Zone 750 W hits that sweet spot with granite stability, advanced cooling features, low noise and great value.
be quiet! Power Zone BN211 - power supply - 750 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.4/ EPS12V 2.92
80 PLUS Certification
80 PLUS Bronze
1.87 kg
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
750 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin +12V with detachable 4 pin section , 4 x 8 pin PCI Express power with detachable 2 pin section , 4 x 4 PIN internal power , 8 x 15 pin Serial ATA power , 4 x 8 pin PCI Express power with detachable 2 pin section , 1 x 4 PIN mini-power connector
Cooling System
135mm fan
Cable ties, thumbscrews
15 cm x 17.5 cm x 8.6 cm
Environmental Standards
ENERGY STAR
5 years warranty
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
750 Watt
Output Current
+3.3V - 25 A , +5V - 25 A , +12V1 - 62 A , -12V - 0.3 A , +5VSB - 3 A
Efficiency
90%
80 PLUS Bronze
Power cable - external - 1.5 m
MTBF
100,000 hours
Cooling System
135mm fan
Overheat protection, over current protection, over voltage protection, overpower protection, SLI ready, undervoltage protection, dual 12V rails, temperature controlled fan, CrossFireX ready
TUV, DEMKO, FIMKO, NEMKO, SEMKO, CB, RoHS, WEEE
ENERGY STAR
Limited warranty - 5 years
50 °C
15 cm
17.5 cm
8.6 cm
1.87 kg
Shipping Width
24.8 cm
Shipping Depth
32.8 cm
Shipping Height
10.2 cm
Shipping Weight
2.36 kg
Scroll to top
