BT.com
Wishlist
Be Quiet BL026 Shadow Wings SW1 120mm PWM Case Fan
Clearance
Price Drop
Price Drop!
Delivery
Standard Due date unavailable
The decoupled 135 mm Shadow Wings PWM fan ensures a perfect mix of cooling power and noise production. The wave shaped contour on the cooling fins minimizes noise and optimizes the air flow.
Four 8 mm heat pipes transport the heat along the shortest path to the optimal point within the cooling fins. The TopFlow cooler-layout enables ideal cooling not only for the CPU but also for surrounding components.
be quiet! Shadow Wings PWM - case fan
Case fan
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Rifle bearing
Rotation Speed
1500 rpm
Air Flow
50.5 cfm
Noise Level
18.9 dBA
Power Connector
4-pin fan connector
Pulse-width modulation (PWM) support
12 cm x 12 cm x 2.5 cm
Anti-vibration
3 years warranty
Case fan
12 cm
12 cm
2.5 cm
Heatsink & Fan
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Rifle bearing
Rotation Speed
1500 rpm
Air Flow
50.5 cfm
Air Pressure
1.63 mm
Noise Level
18.9 dBA
Power Connector
4-pin fan connector
Operation Voltage
5 - 12 V
Rated Current
0.2 A
Power Consumption
2.4 W
Anti-vibration
TUV S, RoHS, WEEE
Limited warranty - 3 years
Scroll to top
