BT.com
Wishlist
Be Quiet BK019 Dark Rock Pro 3 CPU Cooler
Be Quiet BK019 Dark Rock Pro 3 CPU...
£75.10
15 in stock
£75.10
Add to wishlist
Delivery
Standard 3-5 working days
Dark Rock CPU coolers have long been category leaders, and the significantly upgraded Dark Rock Pro 3 is even more powerful. This virtually inaudible double-tower CPU cooler puts famous be quiet! SilentWings technology in your PC where it really counts. They are excellent for overclocked systems and demanding multi-graphics platforms.
Dark Rock Pro 3 offers top performance-to-noise ratio and the high reliability available. Improved cooling efficiency and really silent operation mean this cooler strikes the perfect balance between cooling and serenity - truly silence and performance without compromises.
Be quiet! Dark Rock PRO 3 - processor cooler
Processor cooler
Package Content
Thermal paste
Dark nickel
Compatibility
Socket 754, Socket 940, LGA775 Socket, Socket 939, LGA1156 Socket, Socket AM2+, LGA1366 Socket, LGA1155 Socket, Socket AM3+, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket
Heatsink Material
Aluminium with copper base
Fan Diameter
135 mm/120 mm
Fan Bearing
Fluid dynamic bearing
Rotation Speed
1400/1700 rpm
Air Flow
57.2-113.8 cfm
Power Connector
4-pin fan connector
Rated Voltage
12 V
7 heatpipes (6mm)
13.7 cm x 15 cm x 16.3 cm
1.2 kg
Nickel plated, Silent Wings
3 years warranty
Processor cooler
Package Content
Thermal paste
13.7 cm
15 cm
16.3 cm
1.2 kg
Dark nickel
Heatsink & Fan
Compatible With
Heatsink Material
Fan Diameter
135 mm/120 mm
Fan Bearing
Rotation Speed
1400/1700 rpm
Air Flow
57.2-113.8 cfm
Air Pressure
1.23-2.1 mm
Power Connector
4-pin fan connector
Rated Voltage
12 V
Power Consumption
3.96 W
7 heatpipes (6mm)
RoHS
Limited warranty - 3 years
£75.10
Save on this ideal PC Build kit!
Save £10.36
£94.65
Scroll to top
