BT.com
Wishlist
Be Quiet BK018 Dark Rock 3 CPU Cooler
Be Quiet BK018 Dark Rock 3 CPU...
£61.50
£61.50
Add to wishlist
Delivery
Standard Due date unavailable
Dark Rock CPU coolers have long been category leaders, and now the significantly upgraded Dark Rock 3 is even more powerful. This virtually inaudible single-tower CPU cooler puts famous be quiet! SilentWings technology in your PC where it really counts. They are excellent for overclocked systems and demanding multi-graphics platforms.
Dark Rock 3 offers top performance-to-noise ratio and the highest reliability available. Improved cooling efficiency and really silent operation mean this cooler strikes the perfect balance between cooling and serenity - truly silence and performance without compromises.
be quiet! Dark Rock 3 - processor cooler
Processor cooler
Package Content
Thermal paste
Dark nickel
Compatibility
Socket 754, Socket 940, LGA775 Socket, Socket 939, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket AM3+, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket
Heatsink Material
Aluminum with nickel plated copper base
Fan Diameter
135 mm
Fan Height
22 mm
Fan Bearing
Fluid dynamic bearing
Rotation Speed
1400 rpm
Air Flow
67.8-113.8 cfm
Power Connector
4-pin fan connector
Rated Voltage
12 V
6 heatpipes (6 mm)
13.7 cm x 9.7 cm x 16 cm
976 g
Nickel plated, Silent Wings
English, German, French, Polish, Spanish
Processor cooler
Package Content
Thermal paste
13.7 cm
9.7 cm
16 cm
976 g
Dark nickel
Heatsink & Fan
Compatible With
Heatsink Material
Fan Diameter
135 mm
Fan Height
22 mm
Fan Bearing
Rotation Speed
1400 rpm
Air Flow
67.8-113.8 cfm
Air Pressure
2.1 mm
Noise & Performance Details
8.4 dBA at 700 rpm , 13.6 dBA at 1050 rpm , 21.1 dBA at 1400 rpm
Power Connector
4-pin fan connector
Rated Voltage
12 V
Rated Current
1.11 A
Power Consumption
1.56 W
6 heatpipes (6 mm)
Mounting Kit
Included
Scroll to top
