BT.com
Wishlist
Be Quiet BK009 Pure Rock Heatsink & Fan All Intel & AMD Sockets 120mm
Be Quiet BK009 Pure Rock Heatsink &...
£30.14
More than 50 in stock
£30.14
Add to wishlist
Delivery
Standard 3-5 working days
With Pure Rock, be quiet! presents a CPU cooler series aimed at the Essential category of PC systems. Bringing be quiet!'s award-winning technology to quiet multimedia and graphics systems, and entry level computers of all types, be quiet! Pure Rock delivers an exceptional price-to-performance ratio.
Pure Rock's compact design is compatible with all current Intel® and AMD™ sockets and fits well into tight spaces. Put famous be quiet! technology into your PC today for low noise operation and maximum of cooling performance at entry level segment.
If you are seeking the best possible mix of performance and price in the Essential CPU cooler segment, your search is over. Pure Rock simply has to be your choice.
Excellent Cooling Efficiency
  • High cooling capacity for this category, at 150W TDP
  • Four 6mm heat pipes with aluminum caps carry heat to cooling fins for high performance
Convenient, Highly Compatible Compact Design
  • Compact design saves space, making cooler compatible with a vast array of equipment and possible installation configurations
  • Design supports mounting from atop the mainboard, greatly increasing convenience
  • Compatibility with all current Intel® and AMD™ sockets
Low-Noise Operation
  • Nine blade silence-optimized 120mm be quiet! PWM fan with high-quality sleeve bearing is optimized for quietness and supports the best balance of cooling performance and silent operation
  • Fan blades are airflow-optimized to reduce noise-generating turbulence
  • Even at 100% PWM function, noise is a scant 26.8dB(A)
Product Conception, Design and Quality Control in Germany
  • 3-year warranty
  • Aluminum finish on top cover and aluminum heat pipe caps
  • Quick support is available via our international hotline, Mondays to Fridays from 9:00am to 5:30pm (CET): +49 (0) 40-736 76 86 - 98
be quiet! Pure Rock processor cooler
Processor cooler
Package Content
Thermal paste
Compatibility
Socket 754, Socket 940, LGA775 Socket, Socket 939, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket AM3+, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket, Socket FM2+, LGA2011-3 Socket
Heatsink Material
Aluminum with nickel plated copper base
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Sleeve bearing
Rotation Speed
1500 rpm
Air Flow
87 cfm
Noise Level
26.8 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
4 heatpipes
12.1 cm x 87.5 cm x 15.5 cm
660 g
English, German, French, Polish, Russian, Spanish
3 years warranty
Processor cooler
Package Content
Thermal paste
12.1 cm
87.5 cm
15.5 cm
660 g
Heatsink & Fan
Compatible With
Heatsink Material
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Sleeve bearing
Rotation Speed
1500 rpm
Air Flow
87 cfm
Air Pressure
1.25 mm
Noise Level
26.8 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Rated Current
0.12 A
Power Consumption
1.44 W
4 heatpipes
Mounting Kit
Included
RoHS, WEEE
Limited warranty - 3 years
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* In addition
Reviewed by Mark on 03/03/2015
Thought this was overkill, after looking at the size of the heatsink and fan supplied with the Athlonx4 860K and how my system runs cool most of the time. When demand is high, it dumps heat efficiently.
5* This looks the part. I thought.
Reviewed by Mark on 01/03/2015
And it is.
Runs quiet.
Athlon 860K running for several hours, temp at or around 40 degrees.
Easy to fit. Fit my mid tower with space to spare.
Scroll to top
