BT.com
Wishlist
Be Quiet 750W PSU - BN252 Dark Power Pro 11 Modular Fluid Dynamic Fan
Be Quiet 750W PSU - BN252 Dark...
£177.27
£177.27
Add to wishlist
Delivery
Standard 1-3 working days
It is a fact of the modern world that high technology requires constant refinement and unending improvement - and that is even truer for those who would be leaders. Dark Power Pro power supplies are renowned as the world's quietest and most efficient high-performance PSUs. The Dark Power Pro 11 750W model takes that a step further with a power conversion topology that delivers 80PLUS Platinum performance, add to that an unparalleled array of enhancements that augment this unit's compatibility, convenience of use, reliability, and safety, and the result is the most technologically-advanced power supply be quiet! has ever built.
be quiet! Dark Power PRO 11 750W - power supply - 750 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.4/ EPS12V 2.92
80 PLUS Certification
80 PLUS Platinum
2.15 kg
Input Voltage
AC 100-240 V
Power Capacity
750 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V , 1 x power 8 pin +12V with detachable 4 pin section , 7 x 4 PIN internal power , 8 x 15 pin Serial ATA power , 6 x 8 pin PCI Express power with detachable 2 pin section , 1 x 6 pin PCI Express power , 2 x 4 PIN mini-power connector
Cooling System
135mm fan
Cable ties, thumbscrews
18 cm x 15 cm x 8.6 cm
Environmental Standards
ENERGY STAR
5 years warranty
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
Power Capacity
750 Watt
Output Current
+3.3V - 25 A , +5V - 25 A , +12V1 - 25 A , +12V2 - 25 A , +12V3 - 30 A , +12V4 - 30 A , -12V - 0.5 A , +5VSB - 3 A
Efficiency
94% at 50% Load, 92.1% at 20% Load, 92.8% at 100% Load
Power Factor (PF)
0.99
80 PLUS Platinum
Power cable - external - 1.5 m
MTBF
100,000 hours
Cooling System
135mm fan
Overheat protection, over current protection, over voltage protection, overpower protection, SLI ready, undervoltage protection, short-circuit protection, 4 x 12V rail, temperature controlled fan, CrossFireX ready, fluid dynamic bearing cooling fan
TUV, CB, FCC, RoHS, WEEE, cTUVus, ERP, RCM
ENERGY STAR
Limited warranty - 5 years
18 cm
15 cm
8.6 cm
2.15 kg
Shipping Width
34.8 cm
Shipping Depth
27.2 cm
Shipping Height
11.8 cm
Shipping Weight
3.7 kg
Scroll to top
