BT.com
Wishlist
Be Quiet 500W Pure Power L8 Rifle Bearing Fan APFC 80+ Bronze PSU
Delivery
Standard Due date unavailable
The Pure Power L8 500 W proves true affordability, means peerless dependability and best-in-class features - not cutting corners and settling for less. Pure Power L8 500 W features rock-solid voltages, strong reliability, high efficiency and exceptional quiet - simply the best combination of features, performance and quality in the class - at a very popular price. Now that is value!
Be quiet! Pure Power L8-500W - power supply - 500 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.4/ EPS12V 2.92
80 PLUS Certification
80 PLUS Bronze
1.93 kg
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
500 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin +12V with detachable 4 pin section , 2 x 8 pin PCI Express power with detachable 2 pin section , 4 x 4 PIN internal power , 5 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector
Cooling System
120 mm fan
Cable ties
15 cm x 15 cm x 8.6 cm
Environmental Standards
ENERGY STAR
3 years warranty
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
500 Watt
Output Current
+3.3V - 24 A , +5V - 15 A , +12V1 - 28 A , +12V2 - 20 A , -12V - 0.3 A , +5VSB - 3 A
Efficiency
84%
80 PLUS Bronze
Cable ties
Power cable - external - 1.5 m
MTBF
100,000 hours
Cooling System
120 mm fan
Overheat protection, over current protection, over voltage protection, overpower protection, undervoltage protection, dual 12V rails, short-circuit protection
TUV, SEMKO, CB, FCC, RoHS, WEEE, cTUVus, ErP Ready
ENERGY STAR
Limited warranty - 3 years
Sound Emission
25.1 dBA
15 cm
15 cm
8.6 cm
1.93 kg
Shipping Width
23 cm
Shipping Depth
28 cm
Shipping Height
10.5 cm
Shipping Weight
2.19 kg
Scroll to top
