BT.com
Wishlist
Be Quiet 400W PSU - BN240 System Power 8 Quiet 12cm Fan 80PLUS
Be Quiet 400W PSU - BN240 System...
£38.12
£38.12
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Wednesday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Especially designed by be quiet! with the price-conscious PC builders in mind - the be quiet! System Power 8 400W, featuring true be quiet! reliability with two 12V-rails and rock-solid voltages. The series is certified 80PLUS efficient and able to support multiple GPUs with two PCIe connectors.
System Power 8's combination of power, quietness for its class and efficiency is far beyond ordinary, letting you build cost-effective and reliable systems - a key differentiator in these days of identical commodities.
be quiet! System Power 8 400W - power supply - 400 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.4
80 PLUS Certification
80 PLUS
1.75 kg
Input Voltage
AC 200-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
400 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin +12V with detachable 4 pin section , 5 x 15 pin Serial ATA power , 2 x 4 PIN internal power , 1 x 4 PIN mini-power connector , 2 x 8 pin PCI Express power with detachable 2 pin section
Cooling System
120 mm fan
15 cm x 14 cm x 8.6 cm
Environmental Standards
ENERGY STAR
3 years warranty
ATX12V 2.4
Input Voltage
AC 200-240 V
Frequency Required
50 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
400 Watt
Output Current
+3.3V - 24 A , +5V - 15 A , +12V1 - 22 A , +12V2 - 18 A , -12V - 0.3 A , +5VSB - 3 A
Efficiency
86%
Power Factor (PF)
0.98
80 PLUS
Power cable - 1.5 m
MTBF
100,000 hours
Cooling System
120 mm fan
Overheat protection, over current protection, over voltage protection, overpower protection, undervoltage protection, dual 12V rails, short-circuit protection
TUV, CB, RoHS, WEEE, RCM, ErP 2014, CU
ENERGY STAR
Limited warranty - 3 years
Sound Emission
25.1 dBA
15 cm
14 cm
8.6 cm
1.75 kg
Shipping Width
19.5 cm
Shipping Depth
9.7 cm
Shipping Height
26.8 cm
Shipping Weight
2.1 kg
Be Quiet 400W PSU - BN240 System Power 8 Quiet 12cm Fan...
£38.12
Save on this ideal PC Build kit!
Save £16.90
£63.47
Scroll to top
