BT.com
Wishlist
Ballistix Tactical 8GB DDR3 2133 MT/s (PC3-17000) CL11 @1.65V UDIMM 240pin
Ballistix Tactical 8GB DDR3 2133...
£43.16
£43.16
Add to wishlist
Delivery
Standard Due date unavailable
If you're serious about gaming, we're serious about you. The Crucial Ballistix Tactical Series delivers the latest features at a price you can afford. If you want solid performance, stability, and compatibility, put the Ballistix Tactical series to work for you.
The Crucial Ballistix Tactical Series is designed for performance enthusiasts, gamers and power users. Ballistix Tactical features increased speeds and timings, and enhanced heat spreader for improved thermal performance. If you are looking for reliable, quality memory ideal for stability and compatibility while kicking up the performance factor, the Ballistix Tactical Series is a perfect fit.
Ballistix Tactical - DDR3 - 8 GB - DIMM 240-pin
RAM memory
8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2133 MHz ( PC3-17000 )
Latency Timings
CL11 ( 11-11-11-27 )
Heat sink, Intel Extreme Memory Profiles (XMP), Black PCB , unbuffered
Voltage
1.65 V
8 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
Non-ECC
Module Configuration
1024 x 64
Voltage
1.65 V
Colour Category
Orange
Scroll to top
