BT.com
Wishlist
Ballistix Tactical 4GB DDR3-1600 1.35V UDIMM VLP Memory
Delivery
Standard Due date unavailable
If you're serious about gaming, we're serious about you. The Crucial Ballistix Tactical Series delivers the latest features at a price you can afford. If you want solid performance, stability, and compatibility, put the Ballistix Tactical series to work for you.
The Crucial Ballistix Tactical Series is designed for performance enthusiasts, gamers and power users. Ballistix Tactical features increased speeds and timings, and enhanced heat spreader for improved thermal performance. If you are looking for reliable, quality memory ideal for stability and compatibility while kicking up the performance factor, the Ballistix Tactical Series is a perfect fit.
Ballistix Tactical - DDR3 - 4 GB - DIMM 240-pin
RAM memory
4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin low profile
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz ( PC3-12800 )
Latency Timings
CL8 ( 8-8-8-24 )
Aluminium heat spreader, Intel Extreme Memory Profiles (XMP) , unbuffered
Voltage
1.35 V
Limited lifetime warranty ( Germany - 10 years )
4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
Speed
Latency Timings
CL8 ( 8-8-8-24 )
Non-ECC
Module Configuration
512 x 64
Voltage
1.35 V
Compatible Slots
1 x memory - DIMM 240-pin
Scroll to top
