BT.com
Wishlist
Ballistix Sport DDR3 8GB (2x4GB) SO-DIMM 204-pin
Delivery
Standard Due date unavailable
The Crucial Ballistix Sport Series is designed for mainstream users and general enthusiasts. A simple, slick heat spreader delivers thermal performance along with standard timings and voltages, making this reliable, quality module ideal for maximum stability and compatibility. With industry-standard specifications, little or no BIOS configuration is required. That means this product installs easily, so you can get up and going / gaming quickly. Available in both DDR2 and DDR3 in the most common and popular speeds and densities, you'll be sure to find a product that suits your needs.
Ballistix Sport - DDR3 - 8 GB: 2 x 4 GB - SO-DIMM 204-pin
RAM memory
8 GB: 2 x 4 GB
Memory Type
DDR3 SDRAM - SO-DIMM 204-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1866 MHz (PC3-14900)
Latency Timings
CL10
Intel Extreme Memory Profiles (XMP), Low Voltage, unbuffered
Voltage
1.35 V
8 GB: 2 x 4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
SO-DIMM 204-pin
Speed
Latency Timings
CL10
Non-ECC
Voltage
1.35 V
Scroll to top
