BT.com
Wishlist
Ballistix Sport DDR3 4GB DIMM 240-pin 1600 MHz/PC3-12800 CL9 1.5V unbuffered non-ECC
Delivery
Standard 3-5 working days
The Crucial Ballistix Sport Series is designed for mainstream users and general enthusiasts. A simple, slick heat spreader delivers thermal performance along with standard timings and voltages, making this reliable, quality module ideal for maximum stability and compatibility. With industry-standard specifications, little or no BIOS configuration is required. That means this product installs easily, so you can get up and going / gaming quickly. Available in both DDR2 and DDR3 in the most common and popular speeds and densities, you'll be sure to find a product that suits your needs.
Ballistix Sport - memory - DDR3 - 4 GB - DIMM 240-pin
RAM memory
4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL9 (9-9-9-24)
Heat sink, unbuffered
Voltage
1.5 V
4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Module Height (inch)
1.18
Speed
Latency Timings
CL9 (9-9-9-24)
Non-ECC
Module Configuration
512 x 64
Voltage
1.5 V
Scroll to top
