BT.com
Wishlist
Ballistix Sport 8GB (2x4GB) DDR3-1600 1.5V UDIMM Memory
Ballistix Sport 8GB (2x4GB)...
£61.20
6 in stock
£61.20
Add to wishlist
Delivery
Standard 3-5 working days
The Crucial Ballistix Sport Series is designed for mainstream users and general enthusiasts. A simple, slick heat spreader delivers thermal performance along with standard timings and voltages, making this reliable, quality module ideal for maximum stability and compatibility. With industry-standard specifications, little or no BIOS configuration is required. That means this product installs easily, so you can get up and going / gaming quickly. Available in both DDR2 and DDR3 in the most common and popular speeds and densities, you'll be sure to find a product that suits your needs.
  • PC3-12800 1600MHz CAS 9-9-9-24
  • Designed for Entry-Level & Mainstream Users
  • Integrated Heat Spreaders
  • 1.5v VDIMM
  • Dual Channel Memory Kit, Ideal for any Intel Sandybridge or AMD AM3 based system
  • Limited Lifetime Warranty
Specification
  • Manufacturers Part Number BLS2CP4G3D1609DS1S00CEU
  • Memory Type DDR 3
  • Memory Speed Rating PC3-12800
  • SPD Speed Rating 1600 MHz
  • Voltage 1.5v
  • Latency 9-9-9-24
  • Error Checking Non ECC
  • Registered/Unbuffered Unbuffered
  • Package Type 2 x 4GB 240Pin DIMMs
  • Warranty Limited Lifetime Warranty
Ballistix Sport - DDR3 - 8 GB : 2 x 4 GB - DIMM 240-pin
RAM memory
8 GB : 2 x 4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz ( PC3-12800 )
Latency Timings
CL9 ( 9-9-9-24 )
Aluminium heat spreader, dual channel , unbuffered
Voltage
1.5 V
Limited lifetime warranty ( Germany - 10 years )
8 GB : 2 x 4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL9 ( 9-9-9-24 )
Non-ECC
Module Configuration
512 x 64
Voltage
1.5 V
Compatible Slots
2 x memory - DIMM 240-pin
Scroll to top
