BT.com
Wishlist
Ballistix Crucial Ballistix Sport DDR4 8GB DIMM 288-pin 2400MHz CL16 1.2V
Ballistix Crucial Ballistix Sport...
£52.36
£52.36
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Friday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
The Crucial Ballistix Sport Series is designed for mainstream users and general enthusiasts. A simple, slick heat spreader delivers thermal performance along with standard timings and voltages, making this reliable, quality module ideal for maximum stability and compatibility. With industry-standard specifications, little or no BIOS configuration is required. That means this product installs easily, so you can get up and going / gaming quickly. Available in both DDR2 and DDR3 in the most common and popular speeds and densities, you'll be sure to find a product that suits your needs.
Ballistix Sport - DDR4 - 8 GB - DIMM 288-pin
RAM memory
8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2400 MHz ( PC4-19200 )
Latency Timings
CL16 ( 16-16-16 )
Unbuffered
Voltage
1.2 V
8 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL16 ( 16-16-16 )
Non-ECC
Unbuffered
Module Configuration
1024 x 64
Voltage
1.2 V
Colour Category
Black, green
Ballistix Crucial Ballistix Sport DDR4 8GB DIMM 288-pin...
£52.36
Save on this ideal PC Build kit!
Save £10.36
£71.91
Scroll to top
