BT.com
Wishlist
Ballistix 16GB Kit (4x4GB) DDR4 2400 MT/s (PC4-19200) CL16 SR x8 Unbuffered DIMM 288pin
Ballistix 16GB Kit (4x4GB) DDR4...
£78.75
£78.75
Add to wishlist
Delivery
Standard Due date unavailable
The Crucial Ballistix Sport Series is designed for mainstream users and general enthusiasts. A simple, slick heat spreader delivers thermal performance along with standard timings and voltages, making this reliable, quality module ideal for maximum stability and compatibility. With industry-standard specifications, little or no BIOS configuration is required. That means this product installs easily, so you can get up and going / gaming quickly. Available in both DDR2 and DDR3 in the most common and popular speeds and densities, you'll be sure to find a product that suits your needs.
Ballistix Sport - DDR4 - 16 GB : 4 x 4 GB - DIMM 288-pin
RAM memory
16 GB : 4 x 4 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2400 MHz ( PC4-19200 )
Latency Timings
CL16 ( 16-16-16 )
Ultra Low Voltage , unbuffered
Voltage
1.2 V
16 GB : 4 x 4 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL16 ( 16-16-16 )
Non-ECC
Module Configuration
512 x 64
Voltage
1.2 V
Scroll to top
