BT.com
Wishlist
Ballistix 16GB (8GBx2) Tactical DDR4 CL16 Unbuffered 288pin
Ballistix 16GB (8GBx2) Tactical...
£102.87
13 in stock
£102.87
Add to wishlist
Delivery
Standard 1-3 working days
If you're serious about gaming, we're serious about you. The Crucial Ballistix Tactical Series delivers the latest features at a price you can afford. If you want solid performance, stability, and compatibility, put the Ballistix Tactical series to work for you.
The Crucial Ballistix Tactical Series is designed for performance enthusiasts, gamers and power users. Ballistix Tactical features increased speeds and timings, and enhanced heat spreader for improved thermal performance. If you are looking for reliable, quality memory ideal for stability and compatibility while kicking up the performance factor, the Ballistix Tactical Series is a perfect fit.
Ballistix Tactical - DDR4 - 16 GB : 2 x 8 GB - DIMM 288-pin
RAM memory
16 GB : 2 x 8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2666 MHz ( PC4-21300 )
Latency Timings
CL16 ( 16-17-17 )
Dual rank, dual channel, Black PCB, Intel Extreme Memory Profiles (XMP 2.0), gunmetal grey heat spreader , unbuffered
Voltage
1.2 V
16 GB : 2 x 8 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL16 ( 16-17-17 )
Non-ECC
Module Configuration
1024 x 64
Chips Organization
X4
Voltage
1.2 V
Ballistix 16GB (8GBx2) Tactical DDR4 CL16 Unbuffered...
£102.87
Save on this ideal PC Build kit!
Save £10.36
£122.42
Scroll to top
