BT.com
Wishlist
B-Tech Universal Projector Ceiling Mount
B-Tech Universal Projector Ceiling...
£68.08
17 in stock
£68.08
Add to wishlist
Delivery
Standard 3-5 working days
  • Suitable for projectors up to 10kg (22lbs)
  • Mounts projector only 115mm (4.5") from ceiling or 280mm (11") with supplied extension rod
  • +/-90° tilt adjustment, +/-90° roll adjustment and 360° swivel
  • Easy to adjust and fix projector in position
  • Steel safety wire for extra security
  • Maximum distance between any two fixing points on projector: 340mm (13.4")
  • Suitable for projectors with M2.5, M3, M4, M5 and M6 fixings
  • Simple installation with all mounting hardware included
Max weight
10kg (22lbs)
Tilt
+/-90°
Roll
+/-90°
Swivel
360°
Scroll to top
