BT.com
Wishlist
B-Tech Large Glass Shelf 500x380mm Glass Shelf 10mm Clear Glass
B-Tech Large Glass Shelf 500x380mm...
£26.35
£26.35
Add to wishlist
Delivery
Standard Due date unavailable
Marketing description is not available.
B-TECH BT7163 - mounting component
Mounting component - pole mount
Mounting Components
Shelf
50 cm x 38 cm
Recommended Use
Audio/video components
Max Load Weight
7.5 kg
Material
Tempered glass
Clear glass
50 cm
38 cm
Material
Tempered glass
Clear glass
AV Furniture
Mounting component
Mounting Components
Shelf
Recommended Use
Placing / Mounting
Pole mount
Max Load Weight
7.5 kg
Scroll to top
