BT.com
Wishlist
B-Tech Large Floor Base for LCD Displays 32"- 60"
B-Tech Large Floor Base for LCD...
£170.00
Hurry, only 1 left in stock!
£170.00
Add to wishlist
Delivery
Standard 1-3 working days
Marketing description is not available.
B-TECH BT4002 LARGE FLOOR BASE - mounting component
Mounting component - floor-standing
Mounting Components
Stand base
89 cm x 61 cm
Recommended Use
LCD display
Recommended Display Size
32" - 60"
Max Load Weight
70 kg
89 cm
61 cm
AV Furniture
Mounting component
Mounting Components
Stand base
Recommended Use
LCD display
Placing / Mounting
Floor-standing
32" - 60"
Max Load Weight
70 kg
Bolt fixing
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Item condition Damaged stock - Item is new but has packaging damage
Ref: 99C0 033997
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£23.84
Ref: 99C0 033998
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£23.84
Ref: 99C0 033999
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£23.84
Ref: 99C0 034000
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£23.84
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Scroll to top
