BT.com
Wishlist
B-Tech Large Flat Screen 50mm Pole Mount with Tilt Black Maximum We
Delivery
Standard Due date unavailable
Marketing description is not available.
B-TECH BT8027 Large Flat Screen 50mm Pole Mount with Tilt - mounting kit
Mounting kit - pole mount
Mounting Components
Pole mount
Tilt
Recommended Use
LCD / plasma panel
Max Load Weight
70 kg
B-TECH BT7850; System 2 BT7850-025, BT7850-05, BT7850-10, BT7850-15, BT7850-20
AV Furniture
Mounting kit
Mounting Components
Pole mount
Recommended Use
LCD / plasma panel
Placing / Mounting
Pole mount
Tilt
Max Load Weight
70 kg
B-TECH BT7850 , B-TECH System 2 BT7850-025, BT7850-05, BT7850-10, BT7850-15, BT7850-20
Scroll to top
