BT.com
Wishlist
B-Tech I-Beam (Girder) Mount for 50mm Poles - Black
B-Tech I-Beam (Girder) Mount for...
£68.08
11 in stock
£68.08
Add to wishlist
Delivery
Standard 3-5 working days
Marketing description is not available.
B-TECH System 2 BT7017 - mounting component
Mounting component
Mounting Components
I-beam clamp, tube mount adapter
Adjustable Width
8-25 cm
Tilt
Max Load Weight
140 kg
System 2 BT7850-025, BT7850-05, BT7850-10, BT7850-15, BT7850-20
Adjustable Width
8-25 cm
AV Furniture
Mounting component
Mounting Components
Cable Management
Cable Management System (CMS)
Tilt
Max Load Weight
140 kg
Adjustable width, lockable
B-TECH System 2 BT7850-025, BT7850-05, BT7850-10, BT7850-15, BT7850-20
Scroll to top
