BT.com
Wishlist
B-Tech Hook on Plasma Mount 860mm - Black
B-Tech Hook on Plasma Mount 860mm -...
£40.35
More than 50 in stock
£40.35
Add to wishlist
Delivery
Standard 3-5 working days
Marketing description is not available.
B-Tech Universal BT8422-PRO - wall mount
Wall mount
3 cm
Recommended Use
LCD / plasma panel
Recommended Display Size
Up to 80"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 800 x 500 mm, 400 x 400 mm, 800 x 400 mm, 600 x 400 mm, 300 x 200 mm, 200 x 100 mm
Max Mounting Pattern Size
825 x 500 mm
Max Load Weight
70 kg
3 cm
AV Furniture
Wall mount
Mounting Components
Wall mount
Recommended Use
LCD / plasma panel
825 x 500 mm
Up to 80"
Max Load Weight
70 kg
Lockable, low profile, hook-on installation
Scroll to top
