BT.com
Wishlist
B-Tech Flat screen wall mount with tilt and swivel
B-Tech Flat screen wall mount with...
£26.16
21 in stock
£26.16
Add to wishlist
Delivery
Standard 3-5 working days
  • Designed for screens up to 32" (81cm) / 20kg (44lbs)
  • Fits screens with VESA mounting patterns: 75mm x 75mm, 100mm x 100mm and 200mm x 100mm
  • Features +17° / -10° tilt and 180° swivel
  • 360° rotation for easy screen levelling and to allow screen to be mounted in landscape or portrait style
  • Security locking screws & Allen key provided for a secure installation
  • Comes pre-assembled for quick and easy three step `hook-on' installation
  • Features `OWLS'™ On Wall Levelling System
  • All mounting hardware included
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Item condition Customer return - item has been used and shows signs of use
Ref: 82KD 034987
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£10.03
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Scroll to top
