BT.com
Wishlist
B-Tech Flat screen wall mount with tilt 15"- 32"
B-Tech Flat screen wall mount with...
£19.66
27 in stock
£19.66
Add to wishlist
Delivery
Standard 3-5 working days
The BT7522 is designed for LCD VESA standard screens with a screen size up to 32", and weight up to 24Kg. The BT7522 has a tilt range of 30ยบ and mounts the screen only 55mm from the wall. A simple two piece installation process is all it takes to mount your screen to the wall.
Unique security screws, together with long hex key, are provided as standard to lock the screen to the bracket and help prevent theft. This bracket can be mounted on single wood studs or concrete/brick walls.
B-TECH BT7522 - wall mount
Wall mount
Tilt
Recommended Use
LCD display
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm, 200 x 100 mm
Max Load Weight
24 kg
AV Furniture
Wall mount
Mounting Components
Tilt wall mount
Recommended Use
LCD display
Tilt
Max Load Weight
24 kg
Security screws
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Item condition Customer return - item has been opened but is in excellent condition
Ref: 8GP3 035534
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£4.04
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Scroll to top
