BT.com
Wishlist
B-Tech Double Vesa LCD Ball Joint Mount- B
B-Tech Double Vesa LCD Ball Joint...
£71.92
£71.92
Add to wishlist
Delivery
Standard Due date unavailable
Marketing description is not available.
B-TECH BT 7515 - wall mount
Wall mount
Tilt
Recommended Use
LCD display
Recommended Display Size
15" - 42"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm, 100 x 200 mm
Max Load Weight
25 kg
Silver
Silver
AV Furniture
Wall mount
Mounting Components
Wall mount, dual arm
Recommended Use
LCD display
Placing / Mounting
Wall-mountable
15" - 42"
Tilt
Max Load Weight
25 kg
Swivel base
Scroll to top
