BT.com
Wishlist
B-TECH BT8504 Cart for LCD/Plasma Panels 30"-50"
B-TECH BT8504 Cart for LCD/Plasma...
£457.70
13 in stock
£457.70
Add to wishlist
Delivery
Standard 1-3 working days
The BT8504 is a trolley designed specifically for displaying large flat panel displays. Suitable for plasma and LCD screens both VESA and non-VESA standard.
4 high qualities, non-marking braked castors are used to allow for easy transportation making this unit ideal for use in boardroom presentations, colleges and schools or for display purposes. Alternate leveling feet are provided as standard.
This system also allows the choice of whether to mount the screen in portrait or landscape styles.
B-TECH BT8504 - cart
Cart
105 cm x 71.1 cm x 168 cm
Recommended Use
LCD / plasma panel
Recommended Display Size
30" - 50"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 400 x 200 mm, 400 x 400 mm, 600 x 400 mm, 300 x 200 mm, 200 x 100 mm, 300 x 300 mm, 200 x 300 mm
Max Load Weight
70 kg
Black base with chrome poles
105 cm
71.1 cm
168 cm
AV Furniture
Cart
Recommended Use
LCD / plasma panel
30" - 50"
Max Load Weight
70 kg
Braked wheels, cable access port
Scroll to top
