BT.com
Wishlist
B-Tech 65" - 95" Heavy Duty Universal Flat Screen Wall Mount
B-Tech 65" - 95" Heavy Duty...
£115.78
More than 50 in stock
£115.78
Add to wishlist
Delivery
Standard 1-3 working days
Wall mount for LCD / Plasma panel. Black Steel. Holds screens from 65".
B-TECH PRO Install BT9903 - wall mount
Wall mount
115 cm x 3.1 cm x 77.3 cm
Recommended Use
LCD / plasma panel
Recommended Display Size
From 65"
Max Mounting Pattern Size
1100 x 730 mm
Max Load Weight
200 kg
Material
Steel
115 cm
3.1 cm
77.3 cm
Material
Steel
AV Furniture
Wall mount
Mounting Components
Wall mount
Recommended Use
LCD / plasma panel
1100 x 730 mm
From 65"
Max Load Weight
200 kg
Hook-on installation
Scroll to top
