BT.com
Wishlist
Axis T8126 High PoE Splitter 12V
Delivery
Standard Due date unavailable
Axis High Power over Ethernet midspan and splitters offer an easy, fast and cost-effective solution for powering network video products - specifically PTZ (pan/tilt/zoom) and PTZ dome network cameras - without the need to install power outlets and electrical cabling.
Axis High Power over Ethernet (High PoE) splitter enables Axis network video products with high power consumption to receive data and power over the same Ethernet cable.
The High PoE products make it easier to install network video products in areas where power cabling and outlets are unavailable. Installation costs are, thereby, reduced.
The splitter conforms to the IEEE 802.3at pre-standard for powering devices with high power requirements on a network.
A splitter, which separates data and power coming over an Ethernet cable, is used for a network video product without built-in support for PoE.
AXIS T8126 High PoE Splitter - PoE splitter
PoE splitter - external
Output Voltage
12 V
Input Connectors
RJ-45
Output connectors
1 x power DC jack
3.1 cm x 7.3 cm x 9.4 cm
AXIS 215 PTZ Network Camera; Network Camera 214 PTZ
Input Connectors
RJ-45
1 x power DC jack
Output Voltage
12 V
1 x Gigabit LAN - RJ-45
Plug and Play, CISPR 22 Class A, CISPR 24, EN55024, EN55022 Class A, WEEE, FCC Part 15 A
0 - 90%
3.1 cm
7.3 cm
9.4 cm
AXIS 215 PTZ Network Camera , AXIS Network Camera 214 PTZ
Scroll to top
