BT.com
Wishlist
AXIS T8120 Midspan 1-port Power Injector 15 Watt
Delivery
Standard Due date unavailable
Power over Ethernet (PoE) offers an easy, fast and cost-effective solution for supplying power to network video products without the need to install power outlets and electrical cabling.
With the use of Axis PoE products, Axis network cameras and video encoders can receive both data and power over a single Ethernet cable. Network video products can thus be installed in areas where traditional power cabling and outlets are unavailable or difficult to install.
AXIS T8120 Midspan 15 W 1-port - PoE injector - 15 Watt
PoE injector - external
450 g
Europe
Input Voltage
AC 100-240 V
Output Voltage
48 V
Power Capacity
15 Watt
Output connectors
1 x RJ-45
6 cm x 14.5 cm x 3.1 cm
AXIS M1011 Network Camera, M1011-W Network Camera, M1013 Network Camera, M1014 Network Camera, M1031-W Network Camera
Europe
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
1 x RJ-45
Output Voltage
48 V
Power Capacity
15 Watt
1 x Gigabit LAN - RJ-45
UL, TUV, cUL, EN55022 Class B, FCC Part 15 B
10 - 90% (non-condensing)
6 cm
14.5 cm
3.1 cm
450 g
Scroll to top
