BT.com
Wishlist
AXIS Q3708-PVE Network Surveillance Camera
AXIS Q3708-PVE Network Surveillance...
£1,912.64
£1,912.64
Add to wishlist
Delivery
Standard Due date unavailable
AXIS Q3708-PVE is a fixed dome network camera with three sensors. It gives you a 180º panoramic overview of large areas, using a single camera. And it's perfect for use in challenging light conditions, both during the day and at night.
AXIS Q3708-PVE - network surveillance camera
Network surveillance camera - fixed dome - outdoor - tamper-proof / weatherproof
20.5 cm x 20.5 cm x 17.2 cm
2.5 kg
White
Wired
Camera
Colour - Day&Night
Max Resolution
2560 x 1920
Frame Rate
30 frames per second
Optical Sensor Type
CMOS - 3 x 1/1.8" - 3 x 5,000,000 pixels
Minimum Illumination
0.3 lux - colour - F2.8 , 0.06 lux - B&W - F2.8
Focal Length Control
Fixed focal
Focal Length
5 mm
Lens Iris
F/2.8
Panning Range (degree)
-180 to +180
Tilting Range (degree)
18 to 75
Ethernet 10Base-T/100Base-TX/1000Base-T
Voltage
PoE Plus
Sharpness control, white balance, auto exposure control, colour control, brightness control, Power over Ethernet, contrast control, Wide Dynamic Range (WDR), ONVIF support, Open Network Video Interface Forum (ONVIF), infrared cut filter, Privacy Mask Function, Video Motion Detection Technology, active tampering alarm, Text Caption Overlay, password protection, Variable Bitrate (VBR), Constant Bitrate (CBR)
3 years warranty
Environmental Parameters (operating)
-40 °C - 55 °C; 10 - 100% (non-condensing) relative humidity
Wired
20.5 cm
20.5 cm
17.2 cm
2.5 kg
Argentina, Australia, China, Japan, South Korea, Brazil, United Kingdom, United States, Europe
Camera
Colour - Day&Night - fixed dome - outdoor - tamper-proof / weatherproof
Digital Video Format
MPEG-4, MJPEG, H.264
Max Digital Video Resolution
2560 x 1920
Exposure Range
1 sec - 1/71500 sec
RAM
2.5 GB
Flash Memory
512 MB
Image Sensor
3 x 5,000,000 pixels CMOS 3 x 1/1.8"
Lens Construction
Fixed focal
Focal Length
5 mm
Lens Iris
F/2.8
Horizontal Field of View (degree)
180
Panning
Range (degree)
-180 to +180
Titling
Range (degree)
18 to 75
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSH, SSL, QOS, CIFS, SFTP
Ports
LAN/power - RJ-45
EN 61000-3-2, EN 61000-3-3, IEC 60529 IP66, EN 61000-6-1, ICES-003 Class A, EN 61000-6-2, UL 60950-1, IEC 60950-1, EN 60950-1, IEC 60068-2-30, KCC, FCC Part 15 B Class A, IEC 60068-2-1, IEC 60068-2-2, IEC 60068-2-78, IEC 62262 IK10, EN 50121-4, IEC 62236-4, VCCI Class A, EN 50581, AS/NZS CISPR 22, RCM, IEC 60950-22, EN 60950-22, UL 60950-22, EN 55024, EN 55022 Class A, KN35, NEMA250 Type 4X, KN32 Class A
White
Power Requirements
PoE Plus
25.5 Watt
Limited warranty - 3 years
-40 °C
55 °C
Relative Humidity (operating)
Accessories
£5.12
£3.87
£12.34
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.82
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.69
£55.96
Scroll to top
