BT.com
Wishlist
Axis Q1765-LE Outdoor Network Camera
Axis Q1765-LE Outdoor Network...
£1,349.53
£1,349.53
Add to wishlist
Delivery
Standard 1-3 working days
AXIS Q1765-LE network camera is a slim, bullet-style outdoor-ready network camera with 18x optical zoom and auto-focus. It delivers SMPTE-compliant HDTV 1080p video in multiple, individually configurable H.264 and motion JPEG video streams. The built-in IR illumination is provided by four, auto adjusting LEDs that are highly power-efficient. AXIS Q1765-LE can cover great distances providing both wide overviews as well as detailed images for identification purposes. In addition, Axis' unique Corridor Format allows effective monitoring with more resolution in vertical scenes such as long streets or long perimeters.
AXIS Q1765-LE Network Camera - network surveillance camera
Network surveillance camera - fixed - outdoor
Audio
Yes: two-way audio capability
Camera Mount Type
Ceiling mount
14.6 cm x 21.9 cm x 10.5 cm
1.8 kg
Wired
Camera
Colour - Day&Night
Optical Zoom
18 x
Max Resolution
1920 x 1080
Frame Rate
30 frames per second
Optical Sensor Type
CMOS - 1/2.9"
Minimum Illumination
0.5 lux - colour - F1.6 - 30 IRE , 0.04 lux - B&W - F1.6 - 30 IRE , 0 lux - IR
Focal Length Control
Vari-focal
Focal Length
4.7 mm - 84.6 mm
Focus Adjustment
Automatic
Lens Iris
F/1.6-2.8
Ethernet 10Base-T/100Base-TX
Voltage
DC 8 - 28 V / AC 20 - 24 V / PoE
Backlight compensation, manual exposure, sharpness control, digital image rotation, white balance, colour control, progressive scanning, brightness control, Power over Ethernet, ONVIF support, infrared cut filter, Arctic Temperature Control, 3D Privacy Mask Function, OptimizedIR
3 years warranty
Environmental Parameters (operating)
-40 °C - 50 °C; 10 - 100% relative humidity
Audio Support
Camera Mount Type
Ceiling mount
Wired
14.6 cm
21.9 cm
10.5 cm
1.8 kg
Camera
Colour - Day&Night - fixed - outdoor
Digital Video Format
MJPEG, H.264, AVC
Max Digital Video Resolution
1920 x 1080
Digital Zoom
12
Exposure Range
2 sec - 1/28000 sec
RAM
256 MB
Flash Memory
128 MB
Image Sensor
CMOS 1/2.9"
Lens Construction
Vari-focal
Optical Zoom
18 x
Focal Length
4.7 mm - 84.6 mm
Lens Iris
F/1.6-2.8
Focus Adjustment
Automatic
Horizontal Field of View (degree)
4 - 59
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSL, QOS, CIFS
1 x network / power - Ethernet 10Base-T/100Base-TX - RJ-45 , 1 x audio - line-in/microphone - mini-phone 3.5 mm , 1 x audio - line-out - mini-phone 3.5 mm , 1 x video - output
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
C-Tick, EN 61000-3-2, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, NEMA Type 4X, EN 61000-6-2, KCC Class A, IP66, EN 50121-4, VCCI Class A, KN24
Power Requirements
Software Included
Drivers & Utilities
Limited warranty - 3 years
-40 °C
50 °C
Relative Humidity (operating)
10 - 100%
Accessories
£5.11
£3.88
£12.50
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.92
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.69
£56.55
Scroll to top
