BT.com
Wishlist
Axis P5512-E PTZ Dome Network Camera
Delivery
Standard Due date unavailable
The outdoor-ready AXIS P5512-E PTZ Network Dome Camera is a compact and affordably priced day and night pan/tilt/zoom camera. It is suitable for surveillance applications in areas such as parking lots, construction sites and business premises.
AXIS P5512-E PTZ Dome Network Camera - network surveillance camera
Network surveillance camera - pan / tilt / zoom - outdoor - dustproof / weatherproof
Camera Mount Type
Wall mount
18.8 cm x 18.8 cm x 15.9 cm
1.2 kg
Wired
Camera
Colour - Day&Night - PAL
Optical Zoom
12 x
Max Resolution
704 x 576
Optical Sensor Type
CCD - 1/4"
Minimum Illumination
1 lux - colour - F1.6 - 30 IRE , 0.01 lux - B&W - F1.6 - 30 IRE
Focal Length Control
Vari-focal
Focal Length
3.8 mm - 46 mm
Focus Adjustment
Automatic
Panning Range (degree)
360
Tilting Range (degree)
180
Ethernet 10Base-T/100Base-TX
Backlight compensation, sharpness control, white balance, alarm function, brightness control, Power over Ethernet, SDHC-card slot, ONVIF support, Advanced Gatekeeper
3 years warranty
Environmental Parameters (operating)
-20 °C - 50 °C; 20 - 80% relative humidity
Camera Mount Type
Wall mount
Wired
18.8 cm
18.8 cm
15.9 cm
1.2 kg
Australia, United Kingdom, Europe
Camera
Colour - Day&Night - pan / tilt / zoom - outdoor - dustproof / weatherproof
Video Format
PAL
Digital Video Format
MPEG-4, MJPEG, H.264
Max Digital Video Resolution
704 x 576
Digital Zoom
4
Exposure Range
1.6 sec - 1/50000 sec
Video Capture
704 x 576 @ 25 fps
RAM
256 MB
Flash Memory
128 MB
Image Sensor
CCD 1/4"
Lens Construction
Vari-focal
Optical Zoom
12 x
Focal Length
3.8 mm - 46 mm
Focus Adjustment
Automatic
Horizontal Field of View (degree)
4.4 - 51.6
Panning
Range (degree)
360
Speed (degree/sec)
Up to 100
Titling
Range (degree)
180
Speed (degree/sec)
Up to 100
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, IGMP, SSL, QOS
1 x network / power - Ethernet 10Base-T/100Base-TX - RJ-45
Clear and smoked domes
C-Tick, VCCI Class B ITE, EN 61000-3-2, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, EN 61000-6-2, EN 60950-1, KCC Class B, IP66
Software Included
Drivers & Utilities
Limited warranty - 3 years
-20 °C
50 °C
Relative Humidity (operating)
20 - 80%
Accessories
£5.17
£3.90
£12.74
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£9.12
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.70
£57.14
Scroll to top
