BT.com
Wishlist
Axis P3384-VE Network Camera
£902.64
20 in stock
£902.64
Add to wishlist
Delivery
Standard 1-3 working days
AXIS P3384-VE camera provides outstanding video quality including wide dynamic range (WDR) with 'dynamic capture' ensuring that no part of the image is too dark or too bright. The camera is suitable for installations close to large windows and entrances in buildings, in tunnel passages and other areas with bright sunlight and dark shadows, or other strong variations in light.
AXIS P3384-VE integrates Axis Lightfinder technology. The superb light sensitivity, with maintained colors even in very poor lighting conditions, is obtained by a combination of Axis' expertise in image processing, system-on-chip development and selection of the best optical components.
AXIS P3384-VE Network Camera - network surveillance camera
Network surveillance camera - fixed dome - outdoor - vandal / weatherproof
Audio
Yes: two-way audio capability
17.8 cm x 17.8 cm x 12.3 cm
1.7 kg
White
Wired
Camera
Colour - Day&Night
Max Resolution
1280 x 960
Frame Rate
30 frames per second
Optical Sensor Type
CMOS - 1/3"
Minimum Illumination
0.5 lux - colour - F1.2 , 0.08 lux - B&W - F1.2
Focal Length Control
Vari-focal
Focal Length
3 mm - 9 mm
Lens Iris
F/1.2
Panning Range (degree)
360
Tilting Range (degree)
160
Ethernet 10Base-T/100Base-TX
Voltage
PoE
Wide Dynamic Range (WDR), AXIS Video Hosting System (AVHS), ONVIF support, infrared cut filter, P-Iris control, Lightfinder technology, password protection
3 years warranty
Environmental Parameters (operating)
-40 °C - 55 °C; 10 - 100% relative humidity
Audio Support
Wired
17.8 cm
17.8 cm
12.3 cm
1.7 kg
Camera
Colour - Day&Night - fixed dome - outdoor - vandal / weatherproof
Digital Video Format
MJPEG, H.264, AVC
Max Digital Video Resolution
1280 x 960
Exposure Range
2 sec - 1/24500 sec
Video Capture
1280 x 960 @ 30 fps , 160 x 120 @ 30 fps
RAM
256 MB
Flash Memory
128 MB
Image Sensor
CMOS 1/3"
Lens Construction
Vari-focal
Focal Length
3 mm - 9 mm
Lens Iris
F/1.2
Horizontal Field of View (degree)
30 - 84
Panning
Range (degree)
360
Titling
Range (degree)
160
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSL, QOS, CIFS
Alarm Inputs Qty
1
Alarm Outputs Qty
1
1 x network / power - Ethernet 10Base-T/100Base-TX - RJ-45 , 1 x audio - line-in/microphone - mini-phone 3.5 mm , 1 x audio - line-out - mini-phone 3.5 mm
Supported Memory Cards
SD Memory Card, SDHC Memory Card
Smoked dome cover
VCCI, C-Tick, VCCI Class B ITE, EN 61000-3-2, EN 61000-3-3, EN55024, CISPR 22, IEC 60529 IP66, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, NEMA Type 4X, EN 61000-6-2, IEC 60950-1, EN 60950-1, IEC 60068-2-30, IEC 60068-2-27, IEC 60068-2-64, IEC 60068-2-1, IEC 60068-2-2, IEC 60068-2-14, IEC 60068-2-78, IEC 62262 IK10
White
Power Requirements
PoE
Software Included
Drivers & Utilities
Limited warranty - 3 years
-40 °C
55 °C
Relative Humidity (operating)
10 - 100%
Accessories
£5.11
£3.88
£12.50
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.92
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.69
£56.55
Scroll to top
